None of them are really more that plain silver paint. I actually got a roll of chrome tape and cut up sections to fit and installed them.
Voila - bright, SAFE, taillights without over powered bulbs (which get too hot) or having to go LED.
The inside were actually clean except the out side edges. I sand blasted the outside and the inside (outside edge ) where there was little corrosion but no rust.
I hand sanded the inside where the reflective paint was, it came off real easy. I then Primed everything, taped off the outside and paint the chrome inside. It turned out better then I thought the chrome paint could look but maybe this was just what it was made for.
Looks good. Just remember that the tail light housings need to self ground for all of the lghts to work. The housings ground to the mounting studs, and the light bulb sockets ground to the housing. You may want to sand off any paint at those locations or you will be wondering why none of your lights work. Same thing with rear marker lights. They are mounted with a 'fork' shaped spring that grounds to the inside of the rear quarter steel. I can't count the number of threads that are started regarding rear lights not working due to painting all the parts and connections.
WOW! Looks awesome. I thought the housings were just plain metal and not painted from the factory?
Thanks, The inside had a very thin reflective silver coating. The out side may have been plain but I shoot it with aluma blast.
Thanks for the info Harold. I am going to have a look t mine nd possibly upgrade.
As for the plastic polish FLITZ is an excellent product. It is a plastic polish that is sold at tons of retail stores. I also use it to polish metal and glass.
Harold which brand and type of primer did you use? Also, when you said "Aluma Blast" id you mean Eastwood or is there a Krylon paint?
I used the rust-oleum primer inside the tail light housing before spraying the chrome paint and Eastwoods self etching primer outside. I just had picked up the rust-oleum primer on sale 2 4 1 sale and wanted to try it. It worked fine.
I just purchased the Eastwoods aluma blast on sale for 8.99 so I picked up a few cans.
Seymour makes a great aluma blast paint. You can pick it up at different locations. Summit sales for 7.95
Here was what the inside looked like prior to painting the inside.
