I'm trying to remove the radiator support and can not get the screws out where it meets the fender. Looks like they're painted on. Has anyone run into this and solved it? I don't think they're rusted, just maybe super tight and then painted over. Do I try and score where the screw meets the fender? Do I try and heat the screw? Other ideas?
Those are always a bugger. Yours look like they were out for your paint job, so probably are not rusted in. Remember they are not Phillips. You need the right tool.
Thanks. I thought they are #4 Phillips so I got one of those bits. I guess that's not the case. I'll keep researching, but if you can point me to the right tool, I'd appreciate it.
Can't recall what it's called, but there was a thread about that not long ago that someone came up with the name. Give it a day or two and you'll get an answer.
