Anyone have any advice on which company makes a good quality aluminum radiator that will fit like it should in a 68 fbird with a 400/AT? Was curious if there was anything out there other than BeCool which is way too expensive. Ive seen a few online from companys ive never heard of that came with the electric fan for around 200 bucks but im not too sure of fitment or quality.
I installed a Champion brand 3 core in my ‘68 with TH400. I don’t recall what the cost was, but it was quite reasonable. It fit fairly well. It does not have the “clips†on each side that are used to attach the shroud. You’ll have to attach the shroud with screws to the bottom...which was easy. I do recall that the fittings for the tranny cooler lines were not the same size as my lines. I had to find the adapters to match up each end.
I recommend getting the 4 core model, if available. They were out of stock when I needed to replace mine. However, I have not overheated once since installing about 8 years ago.(180 degree thrermostat in south Louisiana)
