Hey guys, mine is leaking on my 400 I just found out. Are they a big deal to change? Any particular sequence to follow or anything tedious to change this gasket?
That would be your oil filter adapter gasket, oil pump is in the pan. Like Big Chief says, simple as pie, just unbolt it scrape off the old gasket and install the new one. Torque is 30 ft/lbs.
Do you have a ramair motor with long branch manifolds (your name is ramair68)? If so, it will have the adapter under the bracket that rotates the filter towards the firewall. That will complicate things.
As I read this subject all I could think of is doing mine with the longbranch and AC.
