Looking for some advice for 3 point seatbelts for front and rear for a 69 vert. Anyone done this have some advice. I've seen the one from Morris which look easy to install for about $350 a pair for the front, but can't find any for the rear. I plan to have kids in the back so it's a must for me.
I installed front seatbelt retractors with shoulder belts from from a 2000 Grand Am (I like to keep my Pontiac all Pontiac parts) and am happy with the results. As far as the rear belts I have no input, nobody ever rides back there.
thanks, did it go into a convertible? If so, what did you use for brackets to attach the rear mounting?
Yes it is a '69 convertible. I mounted the retractors under the ash tray directly to the support located there. The belt comes up between the arm rest and the trim panel. There was no need to cut any of the interior parts. I used the Grand Am guides mounted under the headrest to hold the belts in place. I do have pics somewhere if you would like.
Thanks, that would be great I haven't seen anyone set them up that way. Were your seat upgraded?
I'm going to order a set of Wesco belt first and check them for quality, they look pretty good and like that they don't bolt in with a tall bracket like the Morris belts in the rear. Having them stickup over the doors seems aesthetically unappealing.
Ordered a set from Wesco the other day. They are delayed for 4-6 weeks due to backorders in materials and supplies. Also some colors are completely out so they aren't even providing a timeframe. Luckily Navy color still available and close enough to the Blue I really wanted.
