hi I have a orig 350ho and I benched the orig engine and had a 400ho engine built I am changing a couple of comp lifters for a quieter set anyway currently an 068 cam and wondering if its worth it to upgrade the cam got 3 on my list crower 60916 60242 or summit 2802 406 ci 4 speed 3.36 rear 10.06 compression long tube headers x pipe exhaust 12 int. 21 on dist 10 vac 750 street demon roller 1.5 rockers adjustable valve train d port heads 16 inch vac @ idle power brakes
had 1.65 rockers on but the so called pontiac builder never clearenced for the pushrods
Personally, I like the 068, good performance and near stock idle. Though the 400 I have with it is set up with 1.65s.
Are you willing to give up some idle and vacuum for 20-30 hp gain? If so, I think the 2802 or the 60916 is more of what you are looking for. Little to no gain over the 068 with the 60242.
