Is there a diagram to show me where to run the antenna cable through the dash. I have a rear mounted antenna. Don't remember the correct placement. I have it ran in the left side along the rocker. Routing seems to short to get to radio. It is the original cable.
Ok any more help on this from anyone. There are clips under the convertible top motor to route the cable through . Picture attached. If I run it down the right rocker panel. The cable is way to long. Any more help on this matter would be greatly appreciated! Hope picture works that I downloaded.
The cable on my 68 vert runs down the right rocker sill channel. My car is a very original 60k car. it even has the original clip stays that hold it in place. There are 2 differences that may possibly make it different then yours. The first is it is a Sept. built car so very early. the second is that my car has a manual top, so no pump. The first gen site had a lot of these factory diagrams but disappeared a couple of weeks ago. hopefully someone else can chime in with a good memory or a link to a diagram.
