Does anybody know where I can find an entire hood latch mount assembly? I do not need a oem one. I know they are scarce. Is it possible to modify one from a 69? The parts I'm referring to are 4,6,58,84 from the manual. Classic Industries has a complete one for a 69. Anybody know why this would not work? Any help is appreciated. Trying to keep this build moving forward but am stuck here.
Ames says in there catalog that the one they offer for a 69 will work on 7&8. with modification. I don't remember the difference but did put a factory 400 scooped 69 hood a 68 I had back in the 80's and it fit w/o modification. Ames is a knowledgeable company and if you bought it from them I'm sure there tech line would tell you what you needed to do to make it fit the car.
