Finally got the new posi diff in the car. Also new springs, new axel bearings, all new bushings and spring pads, new brake drums and new hardware, plus refurbished the period correct Lakewood traction bars. Been planning this since before I had kids. (Oldest now getting married) LOL. Went 3:36 with Auburn carrier, and will use a wide ratio Muncie. The Muncie’s 2.52 first Xs the 3:36 should provide a pretty decent take off gear and the 3:36 overall will allow comfortable highway driving. Looking forward to a springtime cruise. Photos below:
Re: Safe T Track rear end build
[Re: cme469]
#32968204/04/2106:14 PM
I just got done putting this 67 rear together. I went with an auburn posi and used some 3.55 gears I had from my GTO rear. There’s a 69 rear in my bird now. I wanted to go back to the 67 rear setup with the traction bars
[Re: cme469]
#32968304/04/2106:16 PM
Was planning on original style monoleafs from Detroit Eaton
I just purchased a very original 400 conv. that the previous owner replaced the mono leafs with multi leafs and U bolts. They bent the brake lines up to get the ubolts over the axle. I wish he wouldn’t have touched it. I think I am going to put the original monoleafs back on and sell the multileafs.
My 67 is currently cobbed together with a 69 rear with multileafs. It came with slapper bars in place of the lower plates. They were hideous so I took them off and had to use 67 lower plates so I could attach the non staggered shocks. Looking forward to returning it to the stock 67 setup
[Re: cme469]
#32969804/05/2105:17 PM
Looks good. Just make sure you flip the bottom return spring on your brakes or your self adjusting system will not work. That is a common thing for people unfamiliar with drum brakes to get wrong.
Good eye barnbird. In my experience self adjusting brakes never seem to adjust to my satisfaction. With the spring in that position they have no chance.
