Selling a set of New Vintage USA (NVU) Performance 3-1 White gauges part number 01257-03. Installed once but never used. $659.99 value. Also, included is a GM Hall Effect Speedometer Sender which is at least $40 - 50.00 value. I have installed the same gauges but with a different color gauge background. They fit perfectly in a 69 dash bezel. These will supposedly fit a 67 and 68 also if using the correct NVU adapter. These can also be installed in various other vehicles, but would contact NVU to verify. For the 69 you have to use the NVU adapter plate and the original 69 gauge housing piece that goes between the gauges and the clear plastic cover. Letting all this ($700.00 Value) go for $400.00 plus shipping. My mistake gives you a good deal on this. Message me if you would like more info and I can provide more pics. Here is a link to the NVU adapter plate you would have to buy. http://newvintageusallc.mybigcommer...pFyAEgwU9QWAYPUNK_7B-agwooYJeiOmehqnVNIU If interested and you have a 67-68 I can also send the link for the adapter you need to work on those years. I have also included a pic of what they look like installed in the 69 dash Bezel at the bottom.
I know this is an old post, but I just wanted to let you know that I worked with NVU on this and actually sent them my dash. They redesigned the mounting bracket to fix the misalignment issues. Just thought anyone considering or perhaps already purchased this set would want to know. They will replace your bracket for free, you just need to call.
