Looking for AN 8 fuel hose and fittings to run from my tank to a filter and then to pump. Looked at aeroquip racing hose but $400 is two arms and a leg too much. Any suggestions? Must be able to use AN 8 fittings to join the fuel pick up, the filter and the pump.
Earl's Performance Speed-Flex has some good line with PTFE which is obviously better than most and not too expensive
https://www.summitracing.com/parts/EAR-620008ERL and there is also Fragola, which I like and am using from my RobbMc fuel tank pickup to my RobbMc pump but cost more for a 20 Ft run
https://www.summitracing.com/parts/fra-602028/overview/ you using a RobbMc fuel pump?
Thank you,
I also have the Robbmc pickup and their filter, have had it for a while but haven't found the line yet.
Was a 20 foot roll enough to go from tank to pump, and did you follow the stock routing?
I haven't run mine yet, but I measured the distance pretty much the stock route even though I cant remember what that measurement was, it was shorter than 20 Ft so I am hoping it is long enough...lol
I had about 4 1/2 feet left over from the 20 foot roll when I did mine.
Thanks Chief,
Now Ordy and I know we're good with the roll.
Thanks Chief,
Yes Sir!!! Thanks Chief!!
