Just a couple questions after running for a while getting warm seems a bit hard to get into 1st also going to reverse will for sure grind a bit
idles about about 900-1000 when warm
when shut off gointo gear no problem is there something regarding syncros ?
Idle speed seems high. I think your set at 600-700 rpms.
Put shifter in neutral position
Start engine
Once engine is hot try this:
Push in clutch
Put shifter into 1st gear
This should work as long as the car is not moving while you try to engage clutch to the pressure plate
If your having trouble verify everything is setup properly. Adjust shifter linkage, clutch adjustment - when does the clutch engage/disengage?
It could be your clutch is not disengaging enough so the pressure plate is sticking too the clutch so it keeps turning thus putting pressure on syn-rows to engage the gears.
Verify/adjust clutch see for more info:
https://firstgenfirebird.org/forums...rue/re-clutch-adjustment.html#Post322422
