Posted By: Phil Vaught Battery Cable Heat Shield - 08/21/11 12:50 AM
Anybody have a battery cable heat shield (tube) that works with the factory longbranch manifolds? (I am looking for the metal tube that bolts to the head and the cable passes through it...factory 400 convertible with longbranch manifolds.)
Thanks!
Posted By: ponti Re: Battery Cable Heat Shield - 08/21/11 06:20 PM
Have 1 that bolts to the backside of the head from a 67 , if needed send a pm with email . thanks
Posted By: salmon38 Re: Battery Cable Heat Shield - 08/21/11 11:15 PM
That factory tube was to protect the wires coming off the engine wire harness down to the starter...
...NOT battery cables.
There was no factory heat shield for the positive battery cable.
Posted By: steveo Re: Battery Cable Heat Shield - 08/23/11 12:23 PM
Phil, If your looking for orginal look. Use the heat shield tubes. Some guys use it to protect spark plug wires that are close to headers. That is what I used on my 68. Get them at most parts store.
Steveo
Posted By: ponti Re: Battery Cable Heat Shield - 08/23/11 06:01 PM
pic. sent
Posted By: Jimc2002 Re: Battery Cable Heat Shield - 08/23/11 06:18 PM
Ditto. I put wire loam on mine (I believe that was original) to protect against abrasion as it routes in from the front and below the long branch. I found a clip by the engine mount that I assumed was for that cable.
Posted By: Banshee Re: Battery Cable Heat Shield - 08/23/11 06:50 PM
I may have one.
Posted By: Gus68 Re: Battery Cable Heat Shield - 08/23/11 06:51 PM
Here are some shots of the starter heat shield tube. Wires come from the wiring harness above.
400 engine with long branch manifolds and stock starter.
Posted By: Jimc2002 Re: Battery Cable Heat Shield - 08/23/11 07:12 PM
That looks like the same as on mine too for the small wires. Do you have that clip by your engine mount as in my photo for the battery + cable to the starter?
Posted By: ponti Re: Battery Cable Heat Shield - 08/23/11 10:26 PM
Same as the 1 i have for sale
Posted By: Gus68 Re: Battery Cable Heat Shield - 08/24/11 03:12 AM
I have to get under the car again to check.
Posted By: Yellowbird Re: Battery Cable Heat Shield - 08/24/11 06:03 AM
I also used the woven cover on the wires where they exit the tube and run to the solenoid to help protect them from the heat off the long branch manifolds.
Posted By: ponti Re: Battery Cable Heat Shield - 08/24/11 11:34 PM
Have 2 if anyone is in need , thanks
Posted By: ponti Re: Battery Cable Heat Shield - 08/29/11 03:52 AM
2 available if anyone is in need , thanks
© Firebird Classifieds & Forums (1967, 1968, and 1969)
