68 Vacuum Diagrams (Again) - 11/16/10 06:03 PM
I almost have this vacuum hose routing issue figured out. It's just that because of the different option combinations, there seems to be different ways that they are routed.
The vacuum diagram found in the parts manual shows the basic layout. The diagram shows the fittings at the back of the carb for the large hose for what I assume is the power brakes along with the red striped hose. But, there is another detail drawing showing the configuration with power brakes. It has what appears to be another small fitting.
What would this one be for? Could it be that it is used for the AC vacuum tank instead of the carb stud vacuum fitting?
Finally, does the air cleaner thermo vacuum valve use the small fitting on the manifold in front of the carb exclusively, or are there other configurations depending on options?
For reference, these are my options:
400 w/TH400
Power brakes
Air conditioning
Again, if anybody has pictures of an original or otherwise correct engine, that would be the perfect solution!
Thanks again for all your help!
Larry
400 w/TH400
Power brakes
Air conditioning
Larry
