Transmission crossmember mounting question - 06/01/12 01:16 AM
It has been a few years since I took out the transmission and motor. I went back to my baggies and found I only have three bolts and for some reason 5 nuts in the bag for the crossmember mount. I do have two washers and bolts for the center mount but I am talking about the crossmember to frame bolt up. I am trying to figure out how the heck that goes back in. I have the motor on the mounts and loosely tightened but I need to figure this out.
Looking at the crossmember it has round holes on one side and oval on the other. Which side do the oval holes need to be? Passenger or drivers?
Also, how does this thing bolt up to the sub-frame? I assume it is laid on top and then bolted on but I am trying to figure out how it is done. For example, do you use nuts and bolts to do it? Nuts on top?
I know it sounds dumb to ask and I wouldn't if I didn't have to but I have been searching everywhere for pics and can't find any and everything I read says, "remove cross member or install cross member" and no explanation or pics.
Any info or pics would really help.
SAM
SAM
