Engine gets Hot after Shut Down - 06/25/18 03:19 AM
Hey Guys, couple questions for you, first off what are most of your guys 400's running for temp cruising around? I have a 68 400 4 Spd and cruising around down the road around 60 its always between 195-205 depending on outside temp, 205 is the hottest it will get moving at speed, if its real hot outside and I'm idling or barely moving through town it will slowly climb up to 210 maybe 215, but in those instances if I park and shut it off the temp gauge will climb and climb which I know is normal to an extent because the engine is hot and nothing is moving, but sometimes it will go up to like 230 maybe even 240 and push a bit of coolant out before it starts going down, start it up and get it circulating and it will go back under 220-215 rather quickly, but shut it down and will climb right up for a period of time, just curious as to this being normal, and if that's hot enough to cause damage? What could a guy do to help it?
Been reading up on the water pump mod that I've seen on several forums, does that apply to the 8 bolt pumps? Not that it will help after engine is shut off, but if it will help keep it a hair cooler while running I'd like to give it a shot.
Thanks in advance!
Thanks in advance!
