Running Temperature - 06/09/19 11:05 AM
Got my car on the road and out to some shows and cruises.
Per the advice from this forum I stuck with the stock copper 4 row radiator instead of going aluminum. I'm hoping this wasnt a mistake as the car runs very warm on just 80 degree night. Not trusting the stock gauges I have an after market temp gauge which I would glance down at as it was pushing 230 degrees. Is this a reasonable temp. People say these cars run hot but 230? When driving on open road with wind being pushed through its more like 200 degrees.
The other thing I noticed the hotter it ran the more the throttle seemed to run higher, almost made the pedal feel as if it had a sticking feel. Would run at about 1800 RPMS until I revved it up over 3000 RPM then it would drop back down to 900 RPM but only until I gave it more throttle and it would stick back over 1800 again. Is this something engine compartment heat may cause? I didnt have this issue on cooler runnings.
