Anybody have any lying around? My 68 currently has a 12 Bolt, wouldn’t mind finding the correct one to have on hand or maybe even install. PHS says it was a 3:36.
Sorry for the ignorance, but what actually distinguishes a Pontiac 10 Bolt from a Chevy? Pontiacs are the 8.2� Chevy had each? Just curious if there is some obvious differences when searching through a swap meet etc?
I would take 200 for housing and carrier and I think I have a ring and pinion gear set also I’m not sure what the gear is I’d have to dig it out of my parts shelf I might even have the backing plates the issue is the shipping I shipped a 350 hood to Ohio thru you ship for 175 the trick is to find someone heading that way and piggy your shipment on to that so it’s cheaper over wise it’s going to pricey
I have a pair of '67 GTO drum brake backing plates you can have for the cost of shipping if you can use them. Don't know if they are the same as Firebird.
