i have a question for the vinyl top guys, can someone take a vinyl top off and paint it or are the roof panels different? and if someone wanted it on can they just weld the little studs on the rear quarters and front window?
Yes, after cleaning/stripping all the goo ofo of it and filling the trim mounting hloes and removing the studs.
To reverse, add studs or screws, and replace the mounting holes for the trim.
Front, side, and rear windows are the same regardless of vinyl top or not. The roof (body) panel is the same too.
If removing the vinal top permanently be prepared to do some body work on the roof. Some of them, if they were slated to receive a cover, they didn't finish off the leaded joints good enough for paint. Mine was in this condition when I pulled the orig cover off.
