I'm thinking of purchasing these but want to see a pic of where they go.
What are these? If they are the stock type looms I have them and can take pix. Not till monday tho as I am on my way to the cabin from work.
David
68 Droptop 400 4 spd.
David,
Nice car! Looks like a 4speed version of mine. Looks like the soloar red on yours is closer to the factory then mine too.
How do you like those those mufflers?
The looms in I saw in the pics look like what come with the plug wires. I was asking about the stock style looms that Ames sells under the number FN417J that bolt to the motor.
I have the looms now. 6 pieces. They come with instructions on where to mount.
From the picture on the sheet that was sent it looks like there is a block just under the valve cover abover the #1 and #7 exhaust manifold and the same with the other side on the #2 and #8. These blocks look to have a bolt hole for a 3/8 x 1/2 x 16 corse thread bolt.
Unfortuanately my 1971 #96 heads don't have all the block mounts shown on the sheet. They must have changed the head design after 1969.
I have two blocks on the passenger side for a AC bracket so I can use one of those. On the driver side it looks like I have one bracket above the #1 exhast but not in the back above the #7.
Looks like I will only get to use 4 of the 6.
Not stock or mine but they look good. May give you some ideas.
Dion '68 'vert
Sorry, I'm trying to keep it looking stock as much as possible.
Here's a couple from my stock 400:
68tpls400 I dont want to highjack this thread but what is the bracket and switch (?) on the front DS of your carb used for? I see you have the th400 kickdown switch in back.
Step-up switch for idle.
Is that for A/C or something?
68ragtop455,
Nice looking wire looms, where did you get them?
Thanks,
Not my engine but belongs to a friend of mine. I liked his looms and bought the same set at a local parts store. They are Mr. Gasket part #9880.
Thank you,
Al.
Topics35,545
Posts298,893
0 members (), 121 guests, and 23 robots.
