Page A-5 — Firebird 400 Convertible (22367)
1968 Pontiac Sales Album
Firebird 400 Hardtop Coupe (22337)
Standard Equipment
Circ-L-Aire Heater and Defroster
Energy-Absorbing Steering Column
Padded Instrument Panel, Sun Visors, and Windshield Corner Posts
Energy-Absorbing Instrument Panel with Smooth, Contoured Knobs and Levers
Anti-Theft Ignition Key Warning Buzzer
Labeled Instrument Panel Control Switches
Wood Grain Appearance Instrument Panel
Instrument Panel Courtesy Lamp, Glove Box Lamp and Ashtray Lamp
Glove Compartment Lock
Cigar Lighter
Parking Brake Warning Light
Reduce-Glare Instrument Panel and Windshield Wiper Arms and Blades
Inside Day-Night Mirror with Deflecting Base
Safety Front Armrests
Rear Armrests with Integral Ashtrays
Slimline Strato-bucket Front Seats
Expanded Morrokide Seat Backs and Cushions
Nylon-blend Loop-pile Carpeting
Padded Vinyl Trim on Upper Door and Rear Quarter Panels
Carpeted Lower Trim Pads on Doors
Seat Belts with Push-Button Buckles for All Passenger Positions
Outer Front Seat Belt Retractors
Folding Front Seat-back Latches
Full Padding on Rear Upper Panel of Front Seat Back
Soft, Low-Profile Window Control Knobs and Coat Hooks
Passenger-Guard Door Locks–All Doors
Safety Door and Window Regulator Handles
Upper-level Ventilation System
Vertical Louvers in Both Rear Quarter Panels
Safety Door Latches and Hinges
Theft-Deterrent Door Locks and Keys
Center Dome Lamp (Exc. Convertibles)
Dual Master Cylinder Brake System with Warning Light
Self-Adjusting Brakes with Corrosion-resistant Brake Lines
Four-Way Hazard Warning Flasher
Lane-Change Feature in Direction Signal Control
Backup Lights
Body Side Marker Lights at Front and Rear
Dual-Speed Electric Windshield Wipers with Washer
Outside Rearview Mirror
Thick Laminate Windshield
Self-Adjusting Hood Latch
Bright Metal Rocker Panel Moldings
Bright Roof Drip Scalp Moldings on Hardtop Coupe
Bright Chrome-Plated Hub Caps
Delco-Eye Energizer Battery
Full-flow Oil Filter
18.5 Gallon Fuel Tank
Safety Rim Wheels
7.35 x 14 “Space-Saver Spare” Tire
Distinctive 400 Equipment
Special Hood with Dual Simulated Air-intake Scoops
4-BBL Quadra-jet Carburetor
Heavy-duty Radiator
“Power-Flex” Fan with 5 Variable-pitch Blades
High-performance Starting Motor
Heavy-duty 61 Amp. Hour Battery
Chrome-plated Rocker Arm covers, Oil Filler Cap and Air Cleaner
Heavy-rated Front and Rear Springs
Heavy-duty Clutch
Dual Exhaust System
Specific Exterior Identification
Pontiac “Vee” Crest on Front Bumper Center Peak
Bright Center Grille Bar
F:70 x 14 Wide-oval Blackwall Tires (4)
Standard Engine
400 Cu. In. V-8, 330 HP, 4-BBL Carb.-Prem. Fuel
Available Engine
400 Cu. In. High Output V-8, 335 HP, 4-BBL Carb.-Prem. Fuel
Standard Transmission
Heavy-duty 3-speed Manual-Floor Shift
Available Transmissions
4-speed Manual-Floor Shift
Automatic-Column Shift
Automatic-Floor Shift (console required)
Exterior Dimensions (inches)
Overall Length
188.8
Wheelbase
108.1
Height
49.9
Overall Width
72.8
Front Tread (Wide-Track)
60
Rear Tread (Wide-Track)
60
Interior Dimensions (inches)
Front
Hip Room
56.3
Shoulder Room
56.7
Head Room (effective)
37.5
Leg Room (maximum effective)
42.5
Rear
Hip Room
47.5
Shoulder Room
47.3
36.8
29.5
Trunk Capacity (usable luggage, cu. ft.
7.2
Note: See page Q-14 for additional specifications.
A-5
Content last modified: July 6, 2026 at 9:42 am
