EXCLUSIVE “SPRINT” OPTION (e-1)
1968 Pontiac Sales Album
Sprint Option
AVAILABLE ON TEMPEST, TEMPEST CUSTOM AND LE MANS (NOT AVAILABLE ON STATION WAGONS)
Here’s a tailor-made package for the new car buyer who demands the ultimate in true sports-car handling, appearance and performance . . . and it’s ideally suited to the all-new look for 1968.
Standard Equipment
Circ-L-Aire Heater and Defroster
Energy Absorbing Steering Column
Padded Instrument Panel, Sun Visors and Windshield Corner Posts
Energy Absorbing Instrument Panel with Smooth, Contoured Knobs and Levers
Anti-theft Ignition Key Warning Buzzer
Labeled Instrument Panel Control Switches
Glove Compartment Lock
Cigar Lighter
Ball Bearing Ashtray
Parking Brake Warning Light
Reduced-glare Instrument Panel, Windshield Wiper Arms and Blades
Inside Day-Night Mirror with Deflecting Base
Safety Front Armrests
Seat Belts with Pushbutton Buckles for all Passenger Positions
Outer Front Seat Belt Retractors
Folding Front Seat-back Latches (2-Doors)
Full Padding on Rear Upper Panel of Front Seat Back
Soft, Low-profile Window Control Knobs and Coat Hooks
Passenger-guard Door Locks—All Doors
Safety Door and Window Regulator Handles
Safety Door Latches and Hinges
Theft-deterrent Door Locks and Keys
Center Dome Lamp (Exc. Convertibles)
Dual Master Cylinder Brake System with Warning Light
Self-adjusting Brakes with Corrosion-resistant Brake Lines
Four-way Hazard Warning Flasher
Lane-change Feature in Direction Signal Control
Backup Lights
Body Side Marker Lights at Front and Rear
Dual-speed Electric Windshield Wipers with Washer
Outside Rearview Mirror
Thick Laminate Windshield
Self-adjusting Hood Latch
Bright Metal Rocker Panel Moldings
Bright Chrome-plated Hub Caps
Delco Eye Energizer Battery
Full-flow Oil Filter
21.5 Gallon Fuel Tank
Safety Rim Wheels
7.75 x 14 Tires
Distinctive “Sprint” Equipment
Wide “Sprint” Stripes on Lower Body Sides—Coupes and Convertibles
OHC 6 “Sprint” Emblem at Front of Both Rocker Panels
Bright Metal Wheel Opening Moldings (Exc. Tempest 4-Dr. Sedan)
Sports-type Front Shock Absorbers and Springs
Heavy-duty Front Stabilizer Bar
Special Highlift Camshaft
Heavy-duty Main and Connecting Rod Bearings
Heavy-duty Cylinder Block
Heavy-duty Dual Valve Springs
Heavy-duty Clutch Assembly
Low-restriction Exhaust System
Low-restriction Air Cleaner
Standard Engine
High-compression OHC 6, 215 HP, 4-BBL Quadra-jet Carburetor—Prem. Fuel
Standard Transmission
3-speed Manual—Floor Shift (3.55:1 Axle Ratio)
Available Transmissions
4-speed Manual—Floor Shift (3.55:1 Axle Ratio)
Automatic—Column Shift (3.23:1 Axle Ratio)
Automatic—Floor Shift (Le Mans Sports Coupe, Hardtop Coupe and Convertible only—3.23:1 Axle Ratio—console required)
Note:
For exterior and interior dimensions, refer to series and model selected.
Note: See page Q-14 for additional specifications.
E-1
Content last modified: July 9, 2026 at 2:39 am
