GTO CONVERTIBLE (24267) (f-3)
1968 Pontiac Sales Album
GTO Convertible
Standard Equipment
Circ-L-Aire Heater and Defroster
Energy Absorbing Steering Column
Padded Instrument Panel and Sun Visors
Energy Absorbing Instrument Panel with Smooth, Contoured Knobs and Levers
Anti-theft Ignition Key Warning Buzzer
Labeled Instrument Panel Control Switches
Glove Compartment Lock
Cigar Lighter
Ball Bearing Ashtray
Parking Brake Warning Light
Reduced-glare Instrument Panel, Windshield Wiper Arms and Blades
Inside Day-Night Mirror with Deflecting Base
Safety Front Armrests
Seat Belts with Pushbutton Buckles for all Passenger Positions
Outer Front Seat Belt Retractors
Folding Front Seat-back Latches
Full Padding on Rear Upper Panel of Front Seat Back
Soft, Low-profile Window Control Knobs and Coat Hooks
Passenger-guard Door Locks—All Doors
Safety Door and Window Regulator Handles
Safety Door Latches and Hinges
Theft-deterrent Door Locks and Keys
Center Dome Lamp
Dual Master Cylinder Brake System with Warning Light
Self-adjusting Brakes with Corrosion-resistant Brake Lines
Four-way Hazard Warning Flasher
Lane-change Feature in Direction Signal Control
Backup Lights
Body Side Marker Lights at Front and Rear
Outside Rearview Mirror
Thick Laminate Windshield
Self-adjusting Hood Latch
Bright Metal Rocker Panel Moldings
Bright Chrome-plated Hub Caps
Delco Eye Energizer Battery
Full-flow Oil Filter
21.5 Gallon Fuel Tank
Safety Rim Wheels
Distinctive GTO Convertible Equipment
Choice of Slimline Strato-bucket Front Seats or Notch-back Bench Front Seat with Center Armrest
Expanded Morrokide Interior
Full Nylon-blend, Loop-pile Carpeting
Carpeted Lower Door Panels
Wood Grain Appearance Instrument Panel
Rear Seat Armrests with Integral Ashtrays
Glove Box, Ashtray and Cigar Lighter Lamps
Instrument Panel Courtesy Lamps
Concealed, Dual-speed Electric Windshield Wipers with Washer
Interior Rear Quarter Lamps
Deluxe Steering Wheel
Exclusive “Endura” Front Bumper
Dual Simulated Air Intake Scoops on Hood
Full-length Bright Metal Rocker Panel Moldings
Bright Metal Wheel Opening Moldings
Decor Group Moldings
Power-operated Top
Shatter-proof Safety Glass, Rear Window
Distinctive Rear-end Appearance
Sports-type Springs and Shock Absorbers
Heavy-duty Stabilizer Bar
Chrome-plated Rocker Arm Covers, Oil Filler Cap and Air Cleaner
Dual Exhaust System
G:77 x 14 Fastrak Redline Tires
Standard Engine
400 Cu. In. V-8, 350 HP, 4-BBL Quadra-jet Carb.—Prem. Fuel
Available Engines
400 Cu. In. V-8, 265 HP, 2-BBL Carb.—Reg. Fuel (Turbo Hydra-Matic only)
400 Cu. In. High Output V-8, 360 HP, 4-BBL Quadra-jet Carb.—Prem. Fuel
Standard Transmission
Heavy-duty 3-speed Manual—Floor Shift
Available Transmissions
4-speed Manual—Floor Shift
Turbo Hydra-Matic—Column Shift
Turbo Hydra-Matic—Floor Shift (console required)
Exterior Dimensions (inches)
Overall Length
200.7
Wheelbase
112
Height
52.5
Overall Width
74.8
Front Tread (Wide-Track)
60
Rear Tread (Wide-Track)
60
Interior Dimensions (inches)
Front
Hip Room
59.8
Shoulder Room
58.8
Head Room (effective)
38.5
Leg Room (maximum effective)
41.2
Rear
Hip Room
48.4
Shoulder Room
45.5
37.0
Leg Room (minimum effective)
32.4
Trunk Capacity (usable luggage, cu. ft.)
N.A.
Note: See page Q-14 for additional specifications.
F-3
Content last modified: July 9, 2026 at 2:40 am
