CATALINA 4-DOOR SEDAN (25269) (h-2)
1968 Pontiac Sales Album
Catalina 4-Door Sedan
Standard Equipment
Circ-L-Aire Heater and Defroster
Energy Absorbing Steering Column
Padded Instrument Panel and Sun Visors
Energy Absorbing Instrument Panel with Smooth, Contoured Knobs and Levers
Anti-theft Ignition Key Warning Buzzer
Labeled Instrument Panel Control Switches
Wood Grain Appearance Instrument Panel
Instrument Panel Map and Courtesy Lamp
Glove Compartment Lock
Cigar Lighter
Glove Box, Ashtray and Cigar Lighter Lamps
Ball Bearing Ashtray
Parking Brake Warning Light
Reduced-glare Instrument Panel, Windshield Wiper Arms and Blades
Inside Day-Night Mirror with Deflecting Base
Safety Front Armrests
Rear Armrests with Integral Ashtrays
Nylon-blend Loop-pile Carpeting
Padded Vinyl Trim on Upper Door and Rear Quarter Panels
Seat Belts with Pushbutton Buckles for all Passenger Positions
Outer Front Seat Belt Retractors
Full Padding on Rear Upper Panel of Front Seat Back
Soft, Low-profile Window Control Knobs and Coat Hooks
Passenger-guard Door Locks—All Doors
Safety Door and Window Regulator Handles
Safety Door Latches and Hinges
Theft-deterrent Door Locks and Keys
Center Dome Lamp
Trunk Lamp
Dual Master Cylinder Brake System with Warning Light
Self-adjusting Brakes with Corrosion-resistant Brake Lines
Four-way Hazard Warning Flasher
Lane-change Feature in Direction Signal Control
Backup Lights
Body Side Marker Lights at Front and Rear
Concealed, Dual-speed Electric Windshield Wipers with Washer
Outside Rearview Mirror
Thick Laminate Windshield
Self-adjusting Hood Latch
Bright Metal Wheel Opening Moldings
Full-length Lower Body Side Moldings with Color-keyed Vinyl Plastic Insert
Bright Chrome-plated Hub Caps
Delco Eye Energizer Battery
Full-flow Oil Filter
26.5 Gallon Fuel Tank
Safety Rim Wheels
8.25 x 14 Tires (Exc. with A.C.)
Standard Engine
400 Cu. In. V-8, 290 HP, 2-BBL Carb.—Prem. Fuel
Available Engines
400 Cu. In. V-8, 265 HP, 2-BBL Carb.—Reg. Fuel (with Turbo Hydra-Matic only)
400 Cu. In. V-8, 340 HP, 4-BBL Carb.—Prem. Fuel
428 Cu. In. V-8, 375 HP, 4-BBL Carb.—Prem. Fuel
428 Cu. In. High Output V-8, 390 HP, 4-BBL Carb.—Prem. Fuel
Standard Transmission
3-speed Manual—Column Shift
Available Transmissions
3-speed Manual—Floor Shift
4-speed Manual—Floor Shift (with 428 Cu. In. engines only)
Turbo Hydra-Matic—Column Shift
Exterior Dimensions (inches)
Overall Length
216.5
Wheelbase
121
Height
54.8
Overall Width
79.8
Front Tread (Wide-Track)
63
Rear Tread (Wide-Track)
64
Interior Dimensions (inches)
Front
Hip Room
63.8
Shoulder Room
62.3
Head Room (effective)
39.1
Leg Room (maximum effective)
42.4
Rear
Hip Room
62.4
Shoulder Room
61.4
37.7
Leg Room (minimum effective)
38.1
Trunk Capacity (usable luggage, cu. ft.)
18.9
Note: See page Q-14 for additional specifications.
H-2
Content last modified: July 9, 2026 at 2:40 am
