GRAND PRIX HARDTOP COUPE (26657) (k-3)
1968 Pontiac Sales Album
Grand Prix Hardtop Coupe
Standard Equipment
Circ-L-Aire Heater and Defroster
Energy Absorbing Steering Column
Padded Instrument Panel, Sun Visors and Windshield Corner Posts
Energy Absorbing Instrument Panel with Smooth, Contoured Knobs and Levers
Anti-theft Ignition Key Warning Buzzer
Labeled Instrument Panel Control Switches
Instrument Panel Map and Courtesy Lamp
Glove Compartment Lock
Cigar Lighter
Glove Box, Ashtray and Cigar Lighter Lamps
Ball Bearing Ashtray
Parking Brake Warning Light
Reduced-glare Instrument Panel, Windshield Wiper Arms and Blades
Inside Day-Night Mirror with Deflecting Base
Safety Front Armrests
Rear Armrests with Integral Ashtrays
Nylon-blend Loop-pile Carpeting
Padded Vinyl Trim on Upper Door and Rear Quarter Panels
Seat Belts with Pushbutton Buckles for all Passenger Positions
Outer Front Seat Belt Retractors
Folding Front Seat-back Latches
Full Padding on Rear Upper Panel of Front Seat Back
Soft, Low-profile Window Control Knobs and Coat Hooks
Passenger-guard Door Locks—All Doors
Safety Door and Window Regulator Handles
Safety Door Latches and Hinges
Theft-deterrent Door Locks and Keys
Center Dome Lamp
Trunk Lamp
Dual Master Cylinder Brake System with Warning Light
Self-adjusting Brake with Corrosion-resistant Brake Lines
Four-way Hazard Warning Flasher
Lane-change Feature in Direction Signal Control
Backup Lights
Body Side Marker Lights at Front and Rear
Concealed, Dual-speed Electric Windshield Wipers with Washer
Outside Rearview Mirror
Thick Laminate Windshield
Self-adjusting Hood Latch
Bright Metal Wheel Opening Moldings
Delco Eye Energizer Battery
Full-flow Oil Filter
26.5 Gallon Fuel Tank
Safety Rim Wheels
8.55 x 14 Tires
Distinctive Grand Prix Hardtop Coupe Equipment
Choice of Strato-bucket Front Seats or Strato-bench Front Seat with Contoured Backs and Free-standing Center Armrest
Choice of All-expanded Morrokide or Combination Cloth and Expanded Morrokide Interior
Floor Console with Locking Compartment (Bucket Seats Only)
Upper-level Ventilation System
Carpeted Lower Door Trim
Carpathian Elm Burl Grain Appearance on Instrument Panel and Door Inserts
Wide, Paddle-type Door Release Handles Integral with Armrests
Taffeta Perforated Headlining
Rear-seat Radio Speaker Grille
Foam-padded Rear-seat Cushion
Deluxe Steering Wheel
Electric Clock
Woven Fiber Package Shelf
Concealed Headlamps
Distinctive Rear-end Appearance
Bright Metal Rocker Panel Moldings
Decor Group Moldings
Deluxe Wheel Discs
Fender Skirts
Dual Exhaust System
Delcotron Alternator-Regulator
Standard Engine
400 Cu. In. V-8, 350 HP, 4-BBL Carb.—Prem. Fuel
Available Engines
400 Cu. In. V-8, 265 HP, 2-BBL Carb.—Reg. Fuel (with Turbo Hydra-Matic only)
428 Cu. In. V-8, 375 HP, 4-BBL Carb.—Prem. Fuel
428 Cu. In. High Output V-8, 390 HP, 4-BBL Carb.—Prem. Fuel
Standard Transmission
3-speed Manual—Floor Shift (console standard)
Available Transmissions
4-speed Manual—Floor Shift (with 428 Cu. In. engines only)
3-speed Manual—Column Shift (with Front Bench Seat)
Turbo Hydra-Matic—Column Shift (with Front Bench Seat)
Turbo Hydra-Matic—Floor Shift (console standard)
Exterior Dimensions (inches)
Overall Length
216.3
Wheelbase
121
Height
53.0
Overall Width
79.8
Front Tread (Wide-Track)
63
Rear Tread (Wide-Track)
64
Interior Dimensions (inches)
Front
Hip Room
63.8
Shoulder Room
62.4
Head Room (effective)
37.9
Leg Room (maximum effective)
42.3
Rear
Hip Room
55.3
Shoulder Room
61.0
37.2
Leg Room (minimum effective)
35.2
Trunk Capacity (usable luggage, cu. ft.)
N.A.
Note: See page Q-14 for additional specifications.
K-3
