1968 AMA Specifications – Engine
AMA Specifications-Passenger Car
— Engine —
MODEL
Firebird
Firebird Sprint
Firebird 350
Firebird H.O.
Firebird 400
Engine – General
Type, no. cyls., valve arr.
Line, 6, Overhead Cam
90 degree V. 8, In-Head
Bore and stroke (nominal)
3.8750    3.525
x
3.8774    3.535
3.8750    3.746
x
3.8774    3.754
4.1200    3.746
x
4.1224    3.754
Piston displcement, cu. in.
250
350
400
Bore spacing
4.4
4.62
No. System (front to rear)
L. Bank
1-2-3-4-5-6 (In-Line)
1-3-5-7
R. Bank
2-4-6-8
Firing Order
1-5-3-6-2-4
1-8-4-3-6-5-7-2
Compres. ratio (nominal)
9.0:1
10.5:1
9.2:1
10.5:1
10.75:1
Cylinder Head Material
Alloy Cast Iron
Cylinder Block Material
Alloy Cast Iron
Cyl. Sleeve-Wet, dry, none
None
Number of mfg. points
Front
Rear
Engine installation angle
3° 35´
Taxable horsepower
Dia>^² x No. Cyl.
2.5
36.0
48.0
54.3
Publishing max. bhp*@eng. RPM
175@4800
215@5200
265@4600
320@5100
330@4800
Publishing max. torque*lb. ft. @eng. RPM
240@2600
255@3800
355@2800
380@3200
430@3300
Recommended fuel regular – premium
Regular
Premium
Rugular
Premium
Premium
Engine – Pistons
Material
Aluminum Alloy
Description and finish
Cam Ground Slipper Type – Tin Plated
Weight (piston only) oz.
19.740 – 19.920
21.010 – 21.190
22.070 – 22.2
Clearance (limits)
Top land
0.024 – 0.029
0.017 – 0.02
Skirt Top
0.0022 – 0.0028 (a)
0.0025 – 0.0031
Skirt Bottom
0.0017 – 0.0033
0.0020 – 0.003
19.740 – 19.920
21.010 – 21.190
22.070 – 22.2
Ring groove depth
No. 1 ring
3.427 – 3.437
3.667 – 3.67
No. 2 ring
3.427 – 3.437
3.667 – 3.67
No. 3 ring
3.446 – 3.456
3.670 -3.68
No. 4 ring
None
(a) Pistons selected for clearance at 1.110 below top of piston.
MODEL
Firebird 250 cu. in. Engines
Firebird 350 cu. in. Engines
Firebird 400 cu. in. Engines
Engine – Rings
Function (top to bottom)
No. 1, oil or comp.
Compression
No. 2, oil or comp.
Compression
No. 3, oil or comp.
Oil
No. 4, oil or comp.
None
Compression
Description – material, coating, etc.
Cast Iron Reverse Twist With –
(a) or (b)
(c) or #1 and #2 Taper Face Moly Channel
Width
0.0778
No. 1 0.0778 No. 2 0.0775
Gap
0.015
0.19
Oil
Multi-Piece (2 Rails and 1 Expander)
Rails: Steel with Chrome Plated O. D.
Expander: Stainless Steel
Width
0.186
Gap
0.035
Expanders
In Oil Ring Assembly
Engine – Piston Pins
Material
SAE 5015
SAE 1016
Length
3.00
3.25
Diameter
0.9272
0.9802
Type
Locked in rod, inpiston, floating, etc.
Locked in Rod
Busing – In rod or piston
None
Busing – Material
None
Clearance
In piston
0.0003 – 0.0005
0.0005 – 0.0007
In rod
Press Fit
Direction and amount offset in piston
To Right – 0.063
Engine – Connecting Rods
Material
SAE 1037, 1038 or 1141
Arma Steel
Weight (oz.)
23.9
31.7
Length (center to center)
5.70
6.625
Bearing
Material and Type
Moraine 100-A (d)(e)(f)
Moraine400-A (d)
Overall Length
0.837
0.88
Clearance (limits)
0.0007 – 0.0027 (g)
0.0005 – 0.0025
0.0005 – 0.0026
End play
0.0085 – 0.0135
0.006 – 0.011 (Total for Two)
(a) 250 1 bbl. Engine: #1 – Barrel Face Moly Channel, #2 – Barrel Face Tin Plated
(b) 250 4 bbl. Engine: #1 – Barrel Face Moly Channel, #2 – Taper Face Moly Channel
(c) 350 2 bbl. Engine: #1 – Taper Face Moly Channel, #2 – Taper Face Tin Plated
(d) Steel backed removable precision
(e) Moraine 400-A on 4 bbl. 250 cu. in. engines
(f) Moraine 400-A on 4 bbl. 350 cu. in. engines
(g) 0.0007 – 0.0028 on 4 bbl. 250 cu. in. engines
MODEL
Engine – Crankshaft
Material
Nodular Iron (d)
Vibration damper type
Rubber Floated Weight
End thrust taken by bearing (No.)
Crankshaft end play
0.002 – 0.006
0.0035 – 0.0085
Main bearing
Material and type
Durex 100-A* Steel Backed, Removable, Precision (b)
Clearance
0.0003 – 0.0019
0.0002 – 0.0017 (c)
Journal
dia. and
bearing
overall
length
No. 1
2.30 x 0.80
3.00 x 0.94
No. 2
2.30 x 0.80
3.00 x 0.94
No. 3
2.30 x 0.80
3.00 x 0.94
No. 4
2.30 x 0.80
3.00 x 1.13
No. 5
2.30 x 0.80
3.00 x 1.59
No. 6
2.30 x 0.80
None
No. 7
2.30 x 1.01
None
Dir. and amt. cyl. offset
None
Crankpin journal diameter
2.00
2.25
*M-400 in lower half of No. 1,2,3, and 4 locations of 4 bbl. 450 cu. in. and 400 cu. in.
(a) Neoprene with fibre glass cord reinforcement
(b) M-400 in all locations of option 6 cylinder 4 bbl. engine
(c) 0.0012 – 0.0028 on Ram Air II Engine option
(d) Arma Steel on Ram Air II engine option
Engine – Camshaft
Location
Overhead
Between Cylinder Banks
Material
Hardened Alloy Cast Iron
Bearings
Material
Aluminum Alloy
Hight Lead Baffit on Steel
Number
Type of Drive
Gear or chain
Belt (a)
Chain
Crankshaft gear or sprocket material
Hardened Cast Iron
Carburized and Hardened Steel
Camshaft gear orsprocket material
Hardened Cast Iron
Aluminum Alloy with Nylon Covered
Timing Chain
No. of links
98 Teeth
60
Width
1.031 – 0.954
0.88 (Morse) – 1.00 (Link be)
Pitch
0.500
0.375
(a) Neoprene with fibreglass cord reinforcement
Engine – Valve System
Hydraulic lifters (Std., opt, NA
Standard
Valves rotator, type (intake, exhaust)
None
Rocker ratio
1.5:1
Operating
tappet
clearance
(indicate hot or cold)
Intake
0
Exhaust
0
MODEL
Firebird
Firebird Sprint
Firebird 350
Firebird H.O.
Firebird 400
Engine – Lubrication System
Type of lubrication (splash,pressure,nozzle
Main bearings
Pressure
Connecting rods
Pressure
Piston pins
Splash
Camshaft bearings
Pressure
Tappets
Pressure
Timing gear or chain
Metered Jet
Cylinder walls
Metered Jet
Oil pump type
Spur Gear
Normal oil pressure (lb. engine rpm)
26 – 36 # 2800 RPM
30 – 40 above 2600 RPM
55 – 60 above 2600 RPM
Oil press. sending unit (elect. or mech.)
Electric
Type oil intake (floating, stationary)
Stationary Screen
Oil filter system (full flow, part., other)
Full Flow
Filter replacement (element, complete)
Complete
Capacity of c case, less filter-refill (qt.)
Oil grade recommended (SAE viscosity and temperature range)
Anticipated Lowest Temp.
Single Viscosity
SAE Number
Acceptable
Alternate
Above Freezing (+32°F.)
20 W
10W – 30
Below Freezing (+0°F. to +32°F.)
10 W
10W – 30
Below Zero
5 W
5W – 20
Engine Service Reqmt. (MM, MS, etc)
MS
Engine – Exhaust System
TYPE (single, single with cross-over, dual, other)
Single (a)
Dual
Muffler No. and type (reverse flow, straight thru, separate resonator
One – Reverse Flow
(b)
One – Reverse Crossflow with Dual Inlets and Outlets (g)
Exhaust pipe dia.(O.D., wall thick.)
Branch
None (c)
2.00 x 0.060
None
Not Used
Main
2.00 x 0.060
2.25 x (d)
2.25 x 0.070
2.25 x 0.060
Front: 2.00 x 0.060 (h) Rear 2.25 x 0.070
Tail pipe dia. (O.D. and wall thickness)
Muffler Outlet Spout (or Spouts) 2.00 x 0.060
2.00 x 0.060 Muffler Outlet Spouts
(a) Dual system standard on H.O., Y pipe joins dual outlet manifold to single exhaust pipe on Sprint, Crossover pipe used on 350.
(b) One crossflow muffler with dual inlets and outlets, reverse flow resonator ahead of muffler in each pipe on dual systems.
(c) Sprint Y pipe legs 2.00 x 0.060.
(d) 0.076 – front section, 0.070 – rear section.
(e) Front section, 2.25 x 0.070 rear section.
(f) Except 350 HO engine which is same as Firebird 400 H.O.
(g) Reverse flow resonator ahead of muffler in each pipe.
(h) 2.25 x 0.076 with H.O. and Ram Air IV options.
Engine – Crankcase Ventilation System
Type (ventilates to atmos., induction system, other)
Standard
Induction System
Optional
None
Control Unit
Make and model
AC Type CV-735C
AC Type CV-679C
Location
Intake Manifold
Push Rod Cover
Energy source (manifold vacuum, carburetor air stream, other)
Manifold Vacuum
Control method (variable orifice, fixed orifice, other)
Variable Orifice
Complete system
Discharges (to intake manifold, carb. air intake, air cleaner intake, other)
Intake Manifold
Air inlet (breather cap, carburetor air cleaner, other)
Through Filter in the Carburetor Air Cleaner
Flame arrestor (screen, check valve, other)
Check Valve
MODEL
Firebird
Firebird Sprint
Firebird 350
Firebird H.O.
Firebird 400
Engine – Fuel System
6 Cyl. Engines
V-8 Engines
Induction type: Carburetor, fuel injection, supercharger.
Carburetor
FuelTank
Refill capacity (U.S. gals.)
18.5
Filler location
Center Rear
Fuel Pump
Type (elec. or mech.)
Mechanical
Locations
Right Front of Engine
Left Front of Engine
Pressure range
4.0 – 5.5
5.0 – 6.5
Vacuum booster (std., optional, none)
None
Fuel Filter
Type
Plastic Fabric in Fuel Tank and Sintered
Locations
Bronze in Carburetor Inlet (a)
Carbure-tor
Choke Type
Automatic
Intake manifold heat control (exhaust or water)
Exhaust
Air cleanertype (d)
Standard
Air Wetted Paper
Optional
Two Stage – Wetted Plastic Foam Over Paper Element
Idle speed (spec.neutral or drive)
N.      D.
Manual   N.
700
800
700
850
850*
Automatic D.
600
600
600
650
650*
Idle A F mix.
(a) Pleated paper instead of sintered bronze in the 1-bble. carb. for manual transmissions and all 4-bbl. carburetors.
**1000 With Ram Air Option
Engine – Cooling System
Type system (pressure, pressure vented, atmospheric, other)
Pressure Vented
Radiator cap relief valve pressure
14-17 P.S.I.
Circulation thermostat
Type (choke, bypass)
Choke
Starts to open at (°F)
190°
Water Pump
Type (centrifugal, other)
Centrifugal
GPM 1000 pump rpm
Number of pumps
One
Drive (V-belt, other)
V-Belt
Bearing type
Sealed Ball Bearing
Bypass recirculation type (inter., ext.)
External
Integral
Radiator core type (cellular, tube and fin, other)
Tube and Center
Cooling system capacity
With heater (qt.)
12.1
18.6(350)
17.8 (400)
Without heater (qt.)
Heater Standard Equipment
Opt. equipment-specify (qt.)
12.7 w/Air Cond.
20.2 (350), 19.4 (400) with A/C
Water jackets full length of cyl. (yes,no)
Yes
Water all around cylinder (yes,no)
Yes
Radiator hose
Lower
Number and type (molded, straight)
One, Molded
Inside diameter
1.75
Upper
One, Molded
Inside diameter
1.50
By-pass
One – External
One – Internal
Inside diameter
5/16
Hose Not Used
Fan
Number of blades and spacing
4 – 76° & 104° (a) (b)
Diameter
17.62
19.0
Ratio-fan to crankshaft rev.
.95:1 (1.08:1 with A/C)
.91:1(1.25:1 with A/C
Fan cutout type
Fluid Clutch-Thermostatically Controlled V-8 (A/C Only)
Bearing type
See Water Pump
*Drivebelts (indicatebelt usedby letter
Fan
A
A,B
A,C
B,C
A
A,B
A
B,D
A
A,B
A,C
B,C
B,D
C
C
E
F,G
E
F,I
E
E
E
F,G
E
F,I
I
Generator-alternator
Water pump
Power Steering
Air Conditioning
NOTES
(a) 7 blade 18 dia. PoWer-Flex fan on 6 cyl. with A/C.
(b) 7 blade 19.5 dia. fan on all V-8 with A/C – 5 blade 19 dia. Power-Flex std. on 400 V-8 except std. 4 blade fan used with Ram Air Option.
Drive Belt Dimensions
* Drive Belt Dimensions
A
C
E
I
K
Angle of V
36°
36°
36°
36°
36°
36°
36°
36°
36°
Nominal Length (SAE)
39.0
51.5
58.0
27.6
54.0
50.0
52.0
59.0
53.5
Width
.38
.47
.47
.38
.38
.38
.47
.47
.47
[Return to AMA Specifications —Index—]
Content last modified: December 25, 2013 at 8:41 am
