Vinyl Top Installation at Factory
Short answer: The vinyl top was a genuine scheduled factory option — not a way to hide bad welds. But if a top was added after the body shop, it was installed at the dealer; there was no facility to apply vinyl at the factory. The factory did weld special trim-mounting studs to the roof of vinyl-top cars (the same kind of studs that hold the window moldings).
From former GM body-shop workers:
- Studs around the window frames were installed freehand, so uneven spacing or edge distance is a tell.
- On cars without a vinyl top, the roof-to-quarter and windshield-post seams were filled with lead solder and ground smooth — a skilled job. Waviness, grind marks near the drip rail, or lead buildup at the drip-rail end mark a new worker’s work; inspectors had “metal finishers” touch up bad ones.
- Vinyl-top cars got a Bondo-like filler in those seams instead (likely to save cost). So if you permanently remove a vinyl top, plan to redo that seam. (Some original vinyl-top cars do show body solder at the pillars and sail panels, just poorly finished, with the rain gutter not sealed.)
