Dual Diaphragm Distributor
Short answer: 1968 was the only year for a dual-diaphragm (advance/retard) distributor, which retarded timing under certain conditions for emissions. Owners complained of a slight backfire while coasting downhill or decelerating, and a service bulletin had dealers disconnect the retard side. Yours likely already has it disconnected — check for a separate vacuum nipple on the advance/retard unit and make sure that vacuum source is plugged.
[pdfjs-viewer url=/dtb/docs/68-T-2.pdf viewer_height=800px fullscreen=true download=false print=true]
[pdfjs-viewer url=/dtb/docs/68-T-2A.pdf viewer_height=800px fullscreen=true download=false print=true]
[pdfjs-viewer url=/dtb/docs/68-I-45.pdf viewer_height=800px fullscreen=true download=false print=true]
