Find the Rearend Gear Ratio
Short answer: Two ways. Read the code: the two-letter code on the rear of the driver’s-side axle tube (halfway between the drum and the “pumpkin”) — wire-brush to read it. Or count turns: chalk-mark the driveshaft yoke and diff housing and the tire; rotate the tire and count driveshaft revolutions — ratio = driveshaft turns ÷ tire turns (e.g., 17 ÷ 5 = 3.4:1).
1967 Axle Codes
Posi Open Ratio
UN XB 2.56
UP XC 2.78
UR XD 2.93
US XE 3.08
UT XF 3.23
UV XG 3.36
UW XH 3.55
UX 3.90
UY 4.33
For reference: Powerglide 1st 1.76 / 2nd 1.00 / Rev 1.76; TH400 1st 2.48 / 2nd 1.48 / 3rd 1.00 / Rev 2.00.
Categories: Wheels, Brakes, and Axle - All, Wheels, Brakes, and Axle - Axle
Leave a Reply
