LE MANS HARDTOP COUPE (23737) (d-2)
1968 Pontiac Sales Album
Le Mans Hardtop Coupe
Standard Equipment
Circ-L-Aire Heater and Defroster
Energy Absorbing Steering Column
Padded Instrument Panel, Sun Visors and Windshield Corner Posts
Energy Absorbing Instrument Panel with Smooth, Contoured Knobs and Levers
Anti-theft Ignition Key Warning Buzzer
Labeled Instrument Panel Control Switches
Glove Compartment Lock
Cigar Lighter
Ball Bearing Ashtray
Parking Brake Warning Light
Reduced-glare Instrument Panel, Windshield Wiper Arms and Blades
Inside Day-Night Mirror with Deflecting Base
Safety Front Armrests
Seat Belts with Pushbutton Buckles for all Passenger Positions
Outer Front Seat Belt Retractors
Folding Front Seat-back Latches
Full Padding on Rear Upper Panel of Front Seat Back
Soft, Low-profile Window Control Knobs and Coat Hooks
Passenger-guard Door Locks—All Doors
Safety Door and Window Regulator Handles
Safety Door Latches and Hinges
Theft-deterrent Door Locks and Keys
Center Dome Lamp
Dual Master Cylinder Brake System with Warning Light
Self-adjusting Brakes with Corrosion-resistant Brake Lines
Four-way Hazard Warning Flasher
Lane-change Feature in Direction Signal Control
Backup Lights
Body Side Marker Lights at Front and Rear
Outside Rearview Mirror
Thick Laminate Windshield
Self-adjusting Hood Latch
Bright Metal Rocker Panel Moldings
Bright Chrome-plated Hub Caps
Delco Eye Energizer Battery
Full-flow Oil Filter
21.5 Gallon Fuel Tank
Safety Rim Wheels
7.75 x 14 Tires (OHC 6)
8.25 x 14 Tires (V-8)
Distinctive Le Mans Hardtop Coupe Equipment
Choice of Slimline Strato-bucket Front Seats or Notch-back Bench Front Seat with Center Armrest
Expanded Morrokide Interiors
Taffeta Perforated Headlining
Full Nylon-blend, Loop-pile Carpeting
Rear-seat Armrests with Integral Ashtrays
Concealed, Dual-speed Electric Windshield Wipers with Washer
Glove Box, Ashtray and Cigar Lighter Lamps
Instrument Panel, Map and Courtesy Lamps
Deluxe Steering Wheel
Full-length Bright Metal Rocker Panel Moldings
Bright Metal Wheel Opening Moldings
Decor Group Moldings
Standard Engine
250 Cu. In. OHC 6, 175 HP, 1-BBL Carb.—Reg. Fuel
Available Engines
250 Cu. In. OHC 6, 215 HP, 4-BBL Quadra-jet Carb.—Prem. Fuel
350 Cu. In. V-8, 265 HP, 2-BBL Carb.—Reg. Fuel
350 Cu. In. High Output V-8, 320 HP, 4-BBL Quadra-jet Carb.—Prem. Fuel
Standard Transmission
3-speed Manual—Column Shift
Available Transmissions
3-speed Manual—Floor Shift (OHC 6)
Heavy-duty 3-speed Manual—Floor Shift (with V-8 engines only)
4-speed Manual—Floor Shift (exc. OHC 6, 1-BBL engine)
Automatic—Column Shift
Automatic—Floor Shift (console required)
Exterior Dimensions (inches)
Overall Length
200.7
Wheelbase
112
Height
51.8
Overall Width
74.8
Front Tread (Wide-Track)
60
Rear Tread (Wide-Track)
60
Interior Dimensions (inches)
Front
Hip Room
59.9
Shoulder Room
58.8
Head Room (effective)
37.5
Leg Room (maximum effective)
41.3
Rear
Hip Room
58.6
Shoulder Room
57.0
36.2
Leg Room (minimum effective)
32.4
Trunk Capacity (usable luggage, cu. ft.)
14.5
Note: See page Q-14 for additional specifications.
D-2
Content last modified: July 9, 2026 at 2:37 am
