TEMPEST CUSTOM 2-SEAT STATION WAGON (23535) (g-1)
1968 Pontiac Sales Album
Tempest Custom 2-Seat Station Wagon
Standard Equipment
Circ-L-Aire Heater and Defroster
Energy Absorbing Steering Column
Padded Instrument Panel and Sun Visors
Energy Absorbing Instrument Panel with Smooth, Contoured Knobs and Levers
Anti-theft Ignition Key Warning Buzzer
Labeled Instrument Panel Control Switches
Glove Compartment Lock
Cigar Lighter
Ball Bearing Ashtray
Parking Brake Warning Light
Reduced-glare Instrument Panel, Windshield Wiper Arms and Blades
Inside Day-Night Mirror with Deflecting Base
Safety Front Armrests
Seat Belts with Pushbutton Buckles for all Passenger Positions
Outer Front Seat Belt Retractors
Full Padding on Rear Upper Panel of Front Seat Back
Soft, Low-profile Window Control Knobs and Coat Hooks
Passenger-guard Door Locks—All Doors
Safety Door and Window Regulator Handles
Safety Door Latches and Hinges
Theft-deterrent Door Locks and Keys
Center Dome Lamp
Dual Master Cylinder Brake System with Warning Light
Self-adjusting Brakes with Corrosion-resistant Brake Lines
Four-way Hazard Warning Flasher
Lane-change Feature in Direction Signal Control
Backup Lights
Body Side Marker Lights at Front and Rear
Dual-speed Electric Windshield Wipers with Washer
Outside Rearview Mirror
Thick Laminate Windshield
Self-adjusting Hood Latch
Bright Metal Rocker Panel Moldings
Bright Chrome-plated Hub Caps
Delco Eye Energizer Battery
Full-flow Oil Filter
21.5 Gallon Fuel Tank
Safety Rim Wheels
7.75 x 14 Tires (OHC 6)
8.25 x 14 Tires (V-8)
Distinctive Tempest Custom Station Wagon Equipment
All-Morrokide Interiors
Full Nylon-blend, Loop-pile Carpeting
Rear-seat Armrests with Integral Ashtrays
Deluxe Steering Wheel
Full-length Bright Metal Rocker Panel Moldings
Two Seats—Second Seat Folding
Concealed Locker Under Cargo Floor
Vinyl Floor Covering in Cargo Area
Bright Tailgate Window Reveal Molding
Crank-operated Tailgate Window
Standard Engine
250 Cu. In. OHC 6, 175 HP, 1-BBL Carb.—Reg. Fuel
Available Engine
350 Cu. In. V-8, 265 HP, 2-BBL Carb.—Reg. Fuel
Standard Transmission
3-speed Manual—Column Shift
Available Transmissions
3-speed Manual—Floor Shift (OHC 6)
Heavy-duty 3-speed Manual—Floor Shift (with V-8 engine only)
4-speed Manual—Floor Shift (with V-8 engine only)
Automatic—Column Shift
Exterior Dimensions (inches)
Overall Length
211.0
Wheelbase
116
Height
54.4
Overall Width
76.3
Front Tread (Wide-Track)
60
Rear Tread (Wide-Track)
60
Interior Dimensions (inches)
Front
Hip Room
59.7
Shoulder Room
58.3
Head Room (effective)
38.4
Leg Room (maximum effective)
42.6
Rear
Hip Room
59.4
Shoulder Room
57.4
38.3
Leg Room (minimum effective)
34.8
Cargo Volume (cu. ft.)
83.1
Note: See page Q-14 for additional specifications.
G-1
Content last modified: July 9, 2026 at 2:40 am
