Rear Speaker Placement
Short answer: All 1967–69 Firebirds with the single rear-speaker option had it on the right side (coupe or convertible) — never center-mounted. Stereo cars had 4 speakers (2 kick panels + 2 rear).
In a convertible, the rear speaker hangs in a cardboard housing (same material as the glovebox) from the rear-seatback support, by two screws, under the top-storage well. A hole is cut through the well and the grille clamps the well liner between it and the housing. Look for factory indentations marking the screw locations; the service manual has install diagrams (some were dealer-installed kits).
Categories: Interior - All, Interior - Radios and Components
Leave a Reply
