I'm not sure what to go with. It has a stock intake. Looking to get the most power and reliability out of it. Would like to have mechanical secondaries as well.
I'm with Jim regarding size. However, you can call Holley tech support. They'll calculate your need based on Cubes, RPM, and volumetric efficiency...and probably come up with the same reccomendation. Not so critical on a vacuum secondary carb.
You may want to reconsider the manual secondaries. I've been advised that they will affect drivability on a "heavy" street car with an automatic tranny(our 'birds aren't considered light in weight). If you're building a racer, do it!
OK fbody69, I went to cliffs web site and started to request a quote. They were asking for rear end ratio and I don't know what was offered in 68. It appears to be a highway gear, runs about 3000-3500 around 70mph w/stock ohc 6er. Also is posi. Forgive me for my ignorance.
