This is a thread to document information that may not be known already for the Body broadcast copy, sometimes also called a Body braodcast sheet.
This is a factory sheet found in the interior of your car sometimes that specifies options . John Schuh is collecting this information as aaprt of the registry for 1967 -1969 Firebirds.
If you find some new bit of Body Broadcast data you can post it here in this forum and send it to John John at the email below for the registry.
You can also ask John for his mailing address to send paper copies. Note the site for the registry entry form as well as the main registry site is listed below also.
---------------------------------- Subject: Re: [FGF] the registry From: <ramair@comcast.net> Date: Sat, 06 Mar 2004 15:29:14 +0000
Just submit it through Geoff's Registry Form Site or email it directly to me.
I believe that HH in the wheel box of this form is the code for 1967 Pontiac 14x6 steel wheels with disc brakes. source PAH publishing 1964-72 Pontiac Muscle car book.
has a TQ. He has the 554 custom trim option that comes standard with deluxe wheel discs. He doesnt have any other options on billing history that indicate extra cost wheel discs, so I think TQ is the deluxe.
I'll just cut and paste what I got from PHS which was real helpful. For the couple options on my car like console and Rally Clock, the cover letter from PHS applied, but here goes: """"""""""""""""""""""""""""""""""""""""" The information on these Billing History cards can be very confussing. That is why we do the decoding for you and high-light the options and equipment for you.
Box "37" gives the axle ratio, which on your car is a "H" or 3.36:1 ratio.
The box "74" with a "2" in it is for an internal assembly operation on your vehicle and is not an option. I believe that "742" is the operation for installing seat or shoulder belts.
Information in box "34", with a "5" denotes the standard GTO engine, a 400 cid, 350 hp motor. Any item that is standard equipment will not be shown on the order form.
Plant code "P" is for the Pontiac Motor Division assembly plant, in Pontiac, Michigan.
Trim code "23" is for a Black Bucket Seat interior.
All of these options should have been high-lited on the information that we sent to you in the information package. I apologize for any confussion.
Jim Mattison Pontiac Historic Services """""""""""""""""""""""""""""""""""""""""" Reed
