Where is the power for the hood mounted tach lamps drawn from? Are they to come on with the headlamps? The harness has a double connector to "splice in" somewhere, but it is not long enough to go all the way forward...
I recall something about the windshield washer return power but would that not have the tach lamps on all the time?
I wired mine into the dash lamps. Don't do that. Since that runs through the dimmer, there's not enough light to see it at night. So you might want full power to the bulb. Also, I believe at some point Pontiac wired it to be on all the time to cut down on fogging up the lens.
I put it on the lamp terminal last nite, I can always move it down one tab if there is a fogging issue...(we never have fog here on the wet coast )...and to prove it, here is a webcam shot from moments ago of the Burrard Bridge and harbour...
LOL, I suppose not....I nearly missed 2 exits on the way to the office this morning, it was so thick....one big temperature inversion the last few days...
