bop posi
bop posi
16165
04/21/04
08:16 PM
Apr 2004
fine69
fine69
Apr 2004
Ok experts, here's another question. Can I use a 14 tooth pinion from a 39 ring gear on a ring gear of 41 that used a pinion of 15? Or vice versa? Are the angle of the ring gears different or is the pinion on the 15 just larger?
Re: bop posi
16166
04/21/04
08:18 PM
Mar 2003
moncure, nc
sixstarved
sixstarved
Mar 2003
moncure, nc
i dont think you can mix and match. they come as a set, and are matched together. the angles and teeth would not mesh correctly.
scott /
Re: bop posi
16167
04/21/04
09:06 PM
Feb 2002
Los Angeles, CA
Q
Quenton
Quenton
Q
Feb 2002
Los Angeles, CA
Scott is right. You must match the gear sets. The ring gear has the combination stamped on it, as should the pinion.
Q
1stgenbirdman
Website
0 members (), 518 guests, and 16 robots.
Highlander
