reading the back of the oil container says "increased levels of zinc to provide outstanding anti-wear protection for engines with either flat tappet or roller type cams."
Thanks for the response. I just look on line and found a Brad Penn distributor nearby. Don't think you can just get off the shelf. If you know of an outlet ie NAPA, Auto-Zone etc. let me know. Thanks
Starting my dad's out with Brad Penn Break In Oil.
same here ,do you put in break in oil -run it say 20 min then drain and change filter and then use regular oil? actually the oil salesman recommended doing the breakin stage twice ,changing the filter each time.
After wiping out FOUR cams in a row, I wish you all the best of luck. I know my scenario was probably the exception, but I cringe everytime I hear someone mention "breaking in" a new cam.
I now have 14k miles on my roller cam/lifters. IMO there is no other way to go!
I'll probly regret this cause i'm cam'n up next month. Always used/use Valvoline 30W with GM EOS for breakin. Then V-30W. Never lost a cam. Dont drive the FB during cold months.
so after running brad penn breakin oil to breakin my engine what oil should i put in next 1) brad penn partial synthetic 2)kendall 15/40 with BG additive i have both on hand so which one should i put in?
