Where are the attachment mounts for the shroud? Mine is attached at the top center bolt and I see a mounting bolt on the lower drivers side but are there other locations that attach the shroud? It appears very flimsy. Also I have seen comments about fillers between the radiator and the core support, does anyone have pictures of these? Thanks in advance. Tom
There is a steel clip that fits the lower passenger side of the shroud and holds it tight to the radiator.
400 cars and A/C cars have rubberized sheets that are die cut and fit the gaps at both sides of the radiator, plus a steel tray below the radiator, plus a pair of steel panels that fit the area between the core support, hood latch, and bumper reinforcement on both sides.
