This may be a dumb question, but I am cleaning the underside of my bird and am stripping the thick tar under the wheel wells. My question - Is this factory tar for "rust proofing" or road tar that I should strip off as part of the restoration? The more I pull off, the more it seems this might be a good protective coat to leave on....
If it is meant to be there, how do I clean it up or restore it? It comes off ok with heat gun though definitely a slow process. If it needs to come off, is there a better way?
It is factory sound deadener/chip guard/weatherseal. It's unsightly but reasonably effective for road stone noise dampening.
If you leave it on you can hit it with underhood black after washing with a soft scrub brush and letting it dry. There are a couple of brands of coatings designed to freshen it up but if it's otherwise in good shape just make it black again.
I had to get a new inner fender for the passenger side due to 40 years of battery acid leaks.
I had to strip the undercoating from the drivers side so I could have both inner fenders powder coated.
Then I made sure I re-applied the coating on both inner fenders after they were done. I buy the undercoating spray cans from Eastwoods. I figured the coating will protect the finish from stones and also cut down on the noise (from the debris hitting them).
Thanks, that helps. I have one spot where the metal is ripped that I need to repair, otherwise it looks good. Glad I asked before wasting too much time stripping it. I will re-apply the tar to seal it.
The original coating was asphalt. According to the '68 Pontiac Sales Manual page Q3; "The inner fender, or shield, designed to utilize wheel splash to rinse away dirt, mud and salt, is protected against corrosion itself by a special coating of asphalt latex."
I used OEM Paints Underbody Preservatek asphalt-based coating to try to duplicate the original protection and look on a new well, a repaired well, and to freshen the other two. I believe it took three cans for the four wells. The bad news is the stuff is about $14 per spray can.
I would not remove any original that is in good shape.
