My HEI was shipped without any directions. When hooked up it gives full advance at idle. Assume I turn the allen wrench clockwise to put more load on the adjustment?
Does anyone have any directions for the adjustment?
If you mean you are getting full vacuum advance at idle, all is good. You may want to experiment with ported vs manifold vacuum to actuate the vacuum advance. It will depend on your combo but ported vacuum is usually a good place to start.
