Help needed,I am being told that the rear quaters for my 69 convertible are on national back order.Can any one confirm this or suggest where to get these?I am in the western mass area.Thanks for any help you can offer.
Or if you mean convertible verses coupe, the coupe quarters can be spliced in quite nicely to a 'vert. True 'vert repop quarters have been listed as 'coming' for years...
the vert 1/4's are available through sherman metal i beleive. maybe back ordered as you describe though. the coupe style will work as described. why not use the 80% as they can be spliced 1" from the upper body line and will retain the "factory" seams?
Andy
I would like the full 1/4's,my drivers side is from a 68 and is pop riveted on not my doing I purchased the car that way.NPD says they have OER full 1/4's but I am not sure of the quality.I have been told Goodmark is about the best you can get.I will keep trying to locate Goodmark panels,I have been searching since December with no luck.If any one may know were to locate these panels please let me know.Thank you all for your comments.The search continues.
Have you tried Matt's Bowties? That's where I bought my Goodmarks.
Matt's has no listing for the full 69 convertible,I will be giving them a call to see if maybe they can aquire a pair of them.Thanks for the suggestion.
