I went to install my new pedals and the original brake pedal has a bolt instead of the pin like the new pedal assembly. Does anyone make the clutch / brake pedal with the bolt arrangement or do I need to try to find the bracket that holds these? I believe to change the bracket the column has to come off and the brake power booster needs to be removed. Thanks in advance. Tom
