Does anyone have a good recommendation for a firewall insulation pad? From what I've read, a lot of people have some trouble getting them to fit right.
I ordered the higher quality molded pad from Ames (FA382A) made by Quiet Ride Solutions, and have 2 problems with it. First, the fuse box cutout is an over-sized square rather than rectangular, and the cutouts for the fuse box mounting screws are on the wrong diagonal. Second, the pad has a metallic foil layer sandwiched between the jute and rubber to reflect heat, but at each opening, the rubber layer is cut slightly larger than the foil and jute layers, so 1/16" to 1/8" of the shiny foil is visible around each cutout.
I just made adjustments to the ill fitting pad where I needed to because starting with that is a HECK of a lot easier that trying to cut a bulk piece of insulation to the back of the firewall and then cutting out all the necessary openings.
I think the new pad is cut for a 69 fuse panel. The pad is advertised as 67-69, but my fuse panel shape is very different than the cutout in the pad. I spent some time making a template of the firewall holes and compared the template and the old pad to the new pad. Except for the fuse panel, I think most of the holes would line up very close to where they need to be. I would try a test install, but I'm planning on returning it, so I need to keep it in as-new condition.
