#206547 08/13/10 12:58 AM
P
P Offline
Just wondering if anyone else has experienced this:
The water neck will sometimes leak coolant very slowly (right where it meets the intake) when the car has been sitting for about a week or so. The seals are as tight as they can be and the gasket is good; I think it's leaking from the changes in temperature - hot days, cool nights.
The problem is that the leak trickles down to the front of the valley pan and into the crankcase through the PCV valve hole. Had to change the oil and filter today because of this.
Mark
68 Firebird 350 auto (sold)
70 Trans Am RAIII 400 4-speed (sold)
2011 Challenger SRT8 IE392 6-speed (sold)
2017 Challenger Hellcat
1966 Dodge Coronet 440
Take it apart and use the right stuff by permatex. http://www.permatex.com/documents/GasketMakerSelector.pdf
The PCV hole has a raised edge. How does the coolant climb over the lip?
Vikki
Restoration Gallery
http://thefirstgensite.com
D Online: Content
Those t-stat housing don't like to be overtightened either, they will warp and crack...you may actually have a hairline crack in it already, not an uncommon incident.
Mine leaked no matter what I did. Bought a new one....problem solved.
P
P Offline
I don't recall seeing that raised lip. I'll take a look tonight and let you know.
Mark
P
P Offline
Seems then the consensus is to use better gasket material and check to see if the water neck is cracked or scored on the bottom and replace if so.
Thanks all.
Mark
