After a hot run on Sunday, I noticed an obvious hissing water leak where the water pump housing meets the engine block. This seal had held for three years since I built the engine, but for some reason is seeping now. Before I pop off the assembly and replace the gasket, any new advice of gasket-seal procedures, best sealant, etc?
Form-a-gasket works great. Put it on both sides of the gaskets. I used it for most of my engine gaskets when I rebuilt my engine 30 yrs ago. I dissembled the engine this year with no leaks and the gasket just peels off! No old gasket to scrap off!
<for pitting and flatness. They can get pretty bad over time around the water ports>
Ditto
Mine didn't leak, and I did it as a pm measure.
Mine was deep enough that it would have distorted the mating surface that covers the crankcase area. So I leveled the whole the mating surface, starting with #36 paper on a longboard, and finishing in, I cannot remeber if it were, #320 or #500, followed by a hand-burnish to acheive an origional texture surface.
I don't know if you can still get it, but the only thing I use is Permatex #2 non hardening sealer. I have a large, 32 oz tube, and a 32 oz bottle of brush/ball-in-cap. Both are militar-issue and have a man-date of 1974, and I have had the stuff since I was a kid. (It was at my parents house when I moved to TX and rediscovered when I came back.) I still use it and used it when I 'painted' my engine. I have had 100% sucess rate with #2, and there have been a few 'shady' installs where the surfaces could have been cleaner.
Surgically clean union areas, not so much sealers, is the key to leak-free bonds. Silicone is an excellent invention and cannot be surpassed in some applications. For instance, it's the only way to install headers, either silicone only or as a gasket sealer. But I don't like silicone as a gasket sealer in engine acessory assemblies.
<for pitting and flatness. I don't know if you can still get it, but the only thing I use is Permatex #2 non hardening sealer. I have a large, 32 oz tube, and a 32 oz bottle of brush/ball-in-cap. Both are militar-issue and have a man-date of 1974, and I have had the stuff since I was a kid. (It was at my parents house when I moved to TX and rediscovered when I came back.) I still use it and used it when I 'painted' my engine. I have had 100% sucess rate with #2, and there have been a few 'shady' installs where the surfaces could have been cleaner.
I use the same stuff. They have all sorts of silicone products now. I used it instead of or enhanced gaskets in my engine back in the 80's with Permatex. I torn down the engine this year and it was still working and I peeled it off with my fingers. The only leaks I had were the front and rear seals!
