I would appreciate some assistance in getting my passenger side electric window to work properly. Apparently, the wire connecting the motor to the switch was missing when I purchased my 68 convertible. I ordered a replacement wire from Parts One and it appears that I am missing something. The part I received consists of 3 wires attached to a 3 hole connector. The connector attaches to the swith which works fine. My problem is that the 3 wires are supposed to hook up to what looks like a 2 prong connector on the window motor. The wires also appear to be too short to connect to the motor. It seems like I am missing the connector that connects to the motor. Any help would be greatly appreciated. Thanks!!
I don't have my harness handy to look at, but the passenger door power window harness feeds through the door and plugs into the main power window harness. I believe this is a 4 wire plug that is located near the top of the kick panel under the dash.
