My 68 firebird 400 the fuel sending unit has only one hose connection and the fuel pump has the inlet out and a assume a vent tube ..i caped the vent tub with a vacume rubber cap a few weeks ago and today it cam off and fuel was spraying out thank God this happened at start up in the garage I put a small hose with a bolt in it but it seems to sill be leaking anyone know what the problem is? the fuel pump is a month old....
My 68 400 has the sender with both lines for the pump return. Pretty sure it was all original since I found this car that was sitting in a barn since 79...If the sender works just fine, you can just get a pump with one line to the tank. Be sure you use a vented cap though to prevent vaporlock.
