Another option is the K2801 cam from Summit which has similar specs, little more lift and would include lifters for the same price as the crane model, worth looking at.
I believe you can get that Melling cam kit mentioned above at Autozone or most other large chain auto parts stores for around $100. Check autozone.com for an exact price.
I looked at the Summit 2801. It's nice because you get more lift, but I was concerned that the narrower LSA would be too lumpy, require a high idle setting (800+ rpm), and be marginal for use with power brakes (less than 14 inches vacuum).
