Possible new route for AC lines for a '68
223133
03/16/11
07:00 PM
Mar 2011
Arizona
DonBecker
DonBecker
Mar 2011
Arizona
I've almost completed my entire list of AC parts:
AC Parts List
I have a '68 coupe with factory air. When I purchased the car the system was open and didn't work. A cursory glance shows all parts are there.
I want to convert over to R-134A, and since I live in Phoenix, I want the AC to blow cold. COLD.
So I decided to just replace all the parts, all at once.
I have some experience with the GM AC setups as I previously restored the AC on a '76 Corvette.
When I went to track down the hoses for the Firebird, I hit a snag. Seems no one makes them...what to do?
EZ-Clip
Basically you buy the hose length you need, the fittings, and use the crimper to seal the ends up.
I've already ordered the crimper set, once I get all the parts on my car I'll be ready to order the right hose and fittings.
I would love to hear if anyone else has used this before, or heard anything about it.
I'm also replacing the TXV and POA valves with an eliminator kit that switches to a pressure actuated clutch cutoff:
POA Update Kit
03/16/11
07:01 PM
1stgenbirdman
0 members (), 459 guests, and 17 robots.
