Getting the bird close to rolling. But of course there is more.
Now it's time for the rear end. A few guys tell me to install a lock up system in the 8.2 , but I have read some forums that it is not ideal.
I think I would prefer to just swap the entire rear for an 8.5 w/posi. Does anyone have or know of an available complete re built bolt in unit for a 68 coupe ,prefer disc brake ,but drums are ok to. with springs, no problem. geared in 3.08 to 3.23 range. I have a wide ratio low geared 4 speed (3.42 1st)so I was advised to keep these gears. I do have a line on a nice unit out of a 69 camaro just need to put in different gears. but will a 69 axle fit the same? What about shock position and multi spring perches? Are the first gen camaro's the same as 68 Birds. 68 has staggerd shocks correct?
I can find lots of 8.5 diffs but they are all from 2nd gen cars. I do not have the facility to do the mods needed. I will arrange all shipping, the vendor only needs to wrap it and put on pallet, load the truck and sign the papers.OR, any suggestions?
I was told and have read that the lockers are more suitable for the strip, for street driving they engage and dis engage while cornering and are very load and clunky. I don't personally know anybody that has used one.
The tranny I have is a BW ST-10 with the 3.42,2.28,1.46,1.00 ratio. Will a 3.36 gear fit into the 8.2 housing? I thought I read some place that only up to 3.23 will fit. I guess I need to go back to the Eaton web site and look a bit closer at applications for Pontiac
The carrier is what matters...higher gears require a different carrier or a ring gear spacer...but wouldn't recommend spacers. The 8.2 housing will accomodate any gear.
I asked the question because some people misconstrue a locker as posi...but assumed you meant posi because nobody uses a Detroit locker on the street.
Determine what gear you want based on your driving style and go from there.
A high 2 low 3 gear will work with one carrier, and the 3..55-4.33 use another.
Si Vis Pacem Parabellum
Plenty of Nova rear ends (8.5) that will bolt right in 70-74. If your lucky they may already have the gears and posi in them. The eaton is also a good way to go with your 8.2.
